New LS Issues
   / New LS Issues #1
PaOkie
Cranberry Township, PA
Looking to Buy
Recently purchased a LS XU5065. Love the tractor and have put about 22 hours on it so far. Now we run into issues that seem to be electrical. We have begun getting an error code E03 but it just flashes on and off in an irregular fashion. My dealer has been great and came out to check on connections and seemed to cure problem but now not only is the error code back but today the radio was randomly turning on and off. Then the kicker, i was moving some dirt around and moving traveling when the tractor just stopped. It never lost power and never lost RPM but just stopped moving. Then about five seconds later it started moving forward again. Dealer thinks it is likely all electrical related but is in contact with LS service rep in NC and is going to come get tractor and go thru it with LS factory folks, but just wondering if anyone else has run into similar issues?
   / New LS Issues #2
Nothing like that but my PTO would come on at times while driving. At the dealer now waiting for a new PTO safety switch to come in.
   / New LS Issues #3
Again, nothing like that on my XR4046, Did turn the key off and pulled out of ignition. Tractor still ran and dash lights dimmed. Place key back in and cycled, and then shutdown normally. Need to have dealer check but have not had problem since, seemed like the internal key switch stuck.
   / New LS Issues #4
PaOkie, I have the same tractor and recently I am having the same stop while moving issue you have had. I seem to think its electrical as well. No clutch slip, no noise the tractor just stops as if you put it in neutral or push the clutch in. Wait a few seconds and off it goes again. I see you had a ground issue with yours. Can you describe in more detail where your ground was disconnected or if there were any other issues regarding this problem.
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
1997 John Deere 8100 MFWD Tractor (A52128)
1997 John Deere...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
