Will S15 (ULSD) affect my fuel system seals?
[FONT=Arial, Helvetica, sans-serif]The "Clean Diesel Fuel Alliance," an industry group consisting of oil and gas producers, engine manufacturers, the American Petroleum Institute (API) and others, states that "engine and vehicle manufacturers are not anticipating that existing [diesel engine] owners will have to make changes to their equipment to operate [on] the new fuel. [/FONT]
[FONT=Arial, Helvetica, sans-serif]A small number of vehicles may require preventative maintenance in the form of upgrading certain engine and fuel system seals that may not perform well in the transition to the new fuel and could leak. Studies of test fleets have indicated that fuel system leaks are not exclusive to a particular engine type, fuel type or geographic region. It is anticipated that only a small fraction of the vehicles will be affected."
A leak in your fuel system can be dangerous, potentially causing fires to occur if diesel fuel comes in contact with hot engine parts. It is recommended that you consult with your vehicle manufacturer for advice about maintaining or replacing the fuel system seals in your vehicle.[/FONT]
[FONT=Arial, Helvetica, sans-serif]Please refer to our technical bulletin
Fuel Links from Seals of Vehicles using Ultra Low Sulfur Diesel for additional information.[/FONT]
