I just purchased 10 partially cleared acres. I am wanting to purchase a tractor for brush clearing/mowing/hay moving/dirt moving. I know nothing about tractors and have a smaller budget. Can I get any suggestions?
I did that about 9 years ago--bought 10 acres of flat pasture land.
My first tractor was a 2005 Kubota B7510HST (21 hp engine, 17 hp pto, hydrostatic tranny, 4WD, power steering) with the LA302 FEL (4-ft wide bucket, about 800 lb lift to 6.5 ft height). Cost: $12.6K plus tax.
Mowed the weeds with a 4-ft wide King Kutter brush hog (aka bush hog, shredder, slasher). Cost: $500 at Tractor Supply.
When I decided to go into haying, I traded that little Bota for a new 2008 Mahindra 5525 (55 hp engine, 45 hp pto, 2WD, gear tranny, power steering, 3 rear hydraulic remotes) with the ML250 FEL (6-ft wide bucket, 2950 lb lift at the pins to 10.5 ft height, skid steer quick disconnect on the FEL arms). Cost: $19K less trade-in.
If your budget is small and you want a tractor with an FEL, that'll put you in the used tractor market. Post back if that's what you want to do and you'll get many suggestions on possible tractors that will fit your situation.
Good luck and welcome to TBN.
