New L5030HSTC or L4630GSTC tomorrow!!
   / New L5030HSTC or L4630GSTC tomorrow!! #1
FamilyFarm
Platinum Member
Crane, MO
Kubota L4740HST, Kubota RTV 1140 Camo
It looks like I finally have to make a decision! I am supposed to be at the dealership (35 miles from my home) tomorrow morning to sign papers on one of these tractors. I was set on the 5030 HST and had not even thought about trying a GST model - never driven one before. Wow, I was impressed with the GST. It was very easy to shift and nice to be able to use the entire range of gears without stopping to shift to L, M, or H as with the HST. There's only 3 pto HP between the 5030 with HST and the 4630 with GST. I'm sure I'd never know the difference. I can see it would take some getting used to the Forward, Reverse lever. I'm thinking hooking up implements and loader work might be easier with the HST. Otherwise, I don't see any disadvantage to the GST.
Either way, I am looking at this:
CAB Tractor
-rear wiper, rear work lights, radio/CD
853 Loader
-QA heavy-duty round back bucket
-pallet forks (?)
-Woods toothbar
-3 chain hooks
Woods Brushbull 6 ft Cutter
Wood HB72 Box Blade
Land Pride LR2584 landscape rake
-dual guage wheels
I think that is all. I'm looking at approx. $36-38k depending on which tractor and whether or not I get the pallet forks.
For those of you that favor one of the tractors over the other, NOW is your LAST CHANCE to convince me! /forums/images/graemlins/grin.gif
Terry
   / New L5030HSTC or L4630GSTC tomorrow!! #2
I'd go 5030. Not enough difference in money from what I've priced not to go 5030. If I wanted smaller than 5030 I'd go 4330, more money saved. But, if the 4330s too small I'd be in a 5030. Hard to find 4630s around here for that reason. Good luck in whatever you decide. Show us a picture when you get it.
   / New L5030HSTC or L4630GSTC tomorrow!! #3
I like the GST as well. I like it for loader work myself. Maybe I'm just use to the forward reverse lever from using larger machines (like a case 580k backhoe) which almost all have a lever similar to that of a GST. The nice thing about a GST and loader work is that you have way more control over the throttle to help speed up the lifting of the loader when under load.
   / New L5030HSTC or L4630GSTC tomorrow!! #4
I will give you my experience with hydro and GST. Each has it strength and weakness. my L48 is better suited for loader work much faster then the GST. my 4630 is a joy when your out working in the field mowing you can change speeds on the fly and make quick work of that task. If you get GST look at the creep speed option I have used creep when hooking up impliments and changing out bucket for forks etc. If I were to have only one tractor I would go with GST with creep.
   / New L5030HSTC or L4630GSTC tomorrow!! #5
L5030HSTC, you will never regret it. power and control.
enjoy and post some pics.
Bob
   / New L5030HSTC or L4630GSTC tomorrow!! #6
For what it's worth, I just went throught the same. I chose the 5030 HSTC because now I won't ever wonder what if I bought the right tractor. I took mine for a spin tonight and it is soooo smooth and powerful.
Go 5030!
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
INGERSOLL RAND COMPRESSOR (A50854)
INGERSOLL RAND...
