New L3901 First 50 Hour Servicing
   / New L3901 First 50 Hour Servicing #1
tderrick
Nashville
L3901 , Ford 8N and 640
I'm at 50 hrs on the new rig and it's servicing time. (L3901 geared)
It doesn't look like a lot needs to be done. Let's see it I have this correct from the manual.
Clutch adjust
Engine oil / filter
grease fittings
then, just a few other things to check.
I don't see work for hydro or tranny yet for geared tractor.
Does this sound right? thx, in advance, for any help
   / New L3901 First 50 Hour Servicing #2
Right or wrong, here’s what we would do;
Engine oil & filter
Fuel filter, drain fuel water separator
Change hydraulic filter, hydro filter if equipped
Check air filter, changing not usually required
Blow out radiator
Check all fluid levels
Grease chassis, loader and any attachments if equipped
Check / tighten wheel attaching hardware and loader frame
Check tire pressures
Check fan belt tension
Check battery cable connections
Wash
OK, thanks for the time
   / New L3901 First 50 Hour Servicing #4
Do yourself a BIG favor and check the front axle fluid level!!! Normally low straight from the dealer on most kubota's! Let us know if yours was done correctly!!!
2022 TAKEUCHI TB2150 EXCAVATOR (A51242)
2022 TAKEUCHI...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
John Deere Hayrack (A50515)
John Deere Hayrack...
2023 JOHN DEERE 50G EXCAVATOR (A51242)
2023 JOHN DEERE...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 66"...
2018 KUBOTA MS-091 TRACTOR (A51243)
2018 KUBOTA MS-091...
