gf5205
- Joined
- Aug 22, 2005
- Messages
- 134
- Location
- Southwest Maine
- Tractor
- JD 5205 JD 5203 Ford 3600 JD 850 JD 755 Kioti DK65
I have been thinking about a new hay mower for awhile. I have used a JD1207 MoCo since 94 and it was a huge improvement over the Ford sickle that I'd used since 75. I've followed every thread about producing hay and there were different opinions on the need for conditioning grass hay.
I wanted a disc MoCo but was concerned about the power requirements. I have two 50 HP tractors and didn't want to go any bigger because of cost, and I'm only haying 30 acres with a yield of about 4000 small squares in one cutting. The disc MoCo reuirements started at about 60 HP so I thought I was going to end up with a new NH Haybine for about $13k. I went to ask the advice of my JD dealer and he thought I could handle a KUHN 243 which is a 7'10" disc MoCo with a flail conditioner.
The reason I was looking new is that my wife gets most of the seat time while I'm at work, so I want something reliable. Also, a new mower should last last as long as I'll keep haying, I'll be 56 next month. My wife said if you're only going to buy one more mower, what are you waiting for?
My dealer promised not to stick me with it if it didn't work out, so I ordered it.
I've mowed about 10 acres with my JD5203 and I have plenty of power to mow. I've mowed at up to 5 MPH, but my tractor gets pushed around the corners at that speed, and the fields aren't real smooth, so I've been mowing at 3.75 MPH, the same as my 1207. Maybe I'll learn how to negotiate the corners better for more speed. I have 400 lbs on the front now, maybe I'll add some. Any advice on corners?
In any event, I think it's going to work out real good, and the cost was less than I expected. The KUHN lists for $17400 plus $400 freight. I traded the 1207 for $3800 for a net of $14k. Since the dealer advertises the 243 for $15k the real trade was $1k for a unit I bought 13 years ago. It was in good shape then, but was probably new in the late 60's or early 70's. The thing that pushed me to make the move was that the rubber was getting thin on the rolls - and new rolls cost $5k plus labor.
That's my story and I'm sticking to it!
Greg
Greg
