New Kioti DK45 SE Zerk Problem
/ New Kioti DK45 SE Zerk Problem #1
mikeinstafford
stafford, va
Kioti DK45 SE HST
I now have about 30 hours on my new DK45 SE and this thing is great. I found that one of my zerk fittings would not accept grease. I took it off and put another one in its place that I knew worked and it still would not accept grease. What is wrong here and is there an easy fix. Its the zerk near where the bucket mounts to the loader that allows the bucket to swing back to keep things from rolling out of the bucket and forward to dump things out of the bucket.
/ New Kioti DK45 SE Zerk Problem #2
Maybe a silly question, but is the gun out of grease? Did you try to force grease throught the zerk when uninstalled? Have you tried another gun? Those are some of my knee-jerk thoughts...
Sent from my LGL35G using TractorByNet
/ New Kioti DK45 SE Zerk Problem #3
If all is fine with the gun and zerk fitting, and assuming the hole the zerk screws into is clear, the next thing to do is change the loading on the pin using the front loader hydraulics (i.e. put force on, or remove force on the pin and fitting to see if this allows grease in). Inspect the pin and the hole in for clearance. If the pin fits too tightly in the hole that could be an issue. Sometimes pins will have a groove to allow easier lubrication.
bumper
/ New Kioti DK45 SE Zerk Problem #4
Hi Mike, try curling the bucket up or down slightly, then try zerk again. Sometimes its just a trial and error thing.
/ New Kioti DK45 SE Zerk Problem #5
The pin could have a blockage. Maybe small piece of metal when it was machined.:)
/ New Kioti DK45 SE Zerk Problem #6
also, make sure there is no pressure on the fitting. Ive found that by raising and lowering loaders, swiveling buckets etc (all of the ones iv'e owner over the years) sometimes its the position a leverage point is in will affect whether it accepts grease or not.
/ New Kioti DK45 SE Zerk Problem #7
That usually works for me. It is especially important for greasing the front axle by pushing down with loader. However, with a brand new tractor and a zerk that has never accepted grease, I too would wonder about debris or a manufacturing issue.
Thanks for all the responses. I will try each and let you know what it was.
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2017 Ford Expedition SUV (A59231)
2017 Ford...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
light tower (A60352)
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
