Having had a 2320 for exactly 3 days - and having done no work with it yet, aside from moving a plow assembly for a Farmall Cub - I'll chime in...
The cycling time of the 200CX leaves a lot to be desired. Maybe it's the cold weather, but even after running if for a half-hour and cycling it over and over, the loader seems 'lethargic.' Certainly compared to my Kubota
BX1500. So, from that standpoint, I wonder if the hydraulics of the 2520 + the extra 2hp at the 3-point isn't actually worth the extra money. That said, the published times aren't too far off my old Kubota, so maybe the cold is really affecting the hydraulics more than I'm giving the machine credit for (it's been in the teens since delivery).
Overall, though, please refer to my posting entitled 'how many upgraded before finding the right tractor.' Despite the complaint above, you'll see that I am enamored with the 2320, especially in comparison to the Kubota
B7610 that I was shopping it against. On paper, the machines are nearly identical - down to the price (the JD was $188 more), with exception to position control. This is the feature that caused me to even test drive the JD. But man, oh man, the difference. So far, to my eye, every detail about the JD is superior. Thicker steel, better ergonomics (i.e. split brakes you can actually use since they're not on the same side as the hydro), far more comfortable seat... Compare just the folding ROPS. Pull 2 pins on the JD and fold it into exactly the right position to reinsert the pins. 27 sec. ordeal. The Kubota requires pulling two pins, unscrewing the bolts, folding it, but supporting it just right so the bolts line up, screw them in... royal pain! Drive-on mid-mount mower. The entire hood assembly, including sides, lifts up out of the way. Etc, etc. In essence, the 2320 is 'new technology' while the Kubota is at least 7 years old and was recently discontinued. I'll be anxious to see if the
B7610 replacement is more like the
B3030 - a premium tractor, like the JD.
Sorry to sound like a rant against Kubota. I really loved my
BX1500 and would happily have bought another Kubota, had the differences between the
B7610 and JD 2320 not been so obvious.
