New jd x758 problems
   / New jd x758 problems #1
r8nger
X748
I just put 26 hours on my new tractor. Some 3pt work, but mostly mowing. I shut it off and cleaned it up after leaf work, and the display was dead when I went to start it.i called the dealer I bought it from, and they picked it up two days later.
I called the service department to explain a couple issues I had with it so far. There was moisture in the display screen , 3pt locking nut came off, the fan was hitting the shroud while mowing side hills, and the dead , no start/power issue.
A week and a half later, they call me back and say it is all set. I asked them what they did, and they told me the plug fell off of the ignition switch. The service guy said it was a common issue, ( you think they would check that when assembling it then). The display wasn稚 wet enough to warrant replacing it at this time ( I guess that痴 what you get for 16k). I then asked him about the fan, he said nothing wrong there, they didn稚 hear anything. I said that痴 crap, the fan and shroud were both damaged. He said ya, something definitely happened there, but it痴 not doing it now. I lost it, yelled at him, that it does it all the time while mowing on side hills. Now he starts talking to me like I知 stupid. I happen to be a forestry heavy equipment mechanic by trade.so then , I asked him about the three point lock, and he tells me the 3 pt is fine , it goes up and down. I am so frustrated at this point, I explained everything very thoroughly, but they only hear what they want to hear.
So next week, I am going to buy the 54 snow thrower for it. I think I need to try another dealer. I can稚 see dealing with this anymore. This was Farmington Valley Equipment in Ct. Has anyone dealt with the other Dealer in Middletown? My father bought a x748 several years ago, and hasn稚 had any issues at all. That is why I went this route, but so far , I am less than pleased.
   / New jd x758 problems #2
The frames flex on these things and that can cause the fan problem. My X748 is on the 3rd radiator from frame flex. I am much more careful now mowing steep ditches and it has been OK.
2018 FORD EXPEDITION (A51406)
2018 FORD...
2019 JOHN DEERE 5090M LOT NUMBER 93 (A53084)
2019 JOHN DEERE...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
