New JD 5055e Normally This Cold Natured?
   / New JD 5055e Normally This Cold Natured? #1
trook
North Central Mississippi
JD 5075E Cab
This past weekend, I looked a the new JD 5055e cab. The tractor seemed to be extremely cold natured when starting considering it was 50-55 degrees outside. It spit and sputtered for several seconds before it began running smoothly. Is this normal for the 3 cylinder JD engine used in the 5045-5065 engines? My JD 4320 is not nearly this cold natured.
If it is this cold natured at 50 degrees, what is it like at 30 degrees??? Is this something to be concerned about?
   / New JD 5055e Normally This Cold Natured? #2
My $0.02 here... but no, there's not much to be concerned about here.
I've owned the 2.9L Powertech in my old 2007 5103 and run it in pretty cold conditions (that's relative here in the south, ha! Cold = below 60!) It fired up every single time I started it - even when it was below 40.
You are most likely hearing the difference in the 3 cylinder engine vs. your 4 cylinder.
Even when I got my new 5075E last month, it sounded different than my 5103 - and they essentially have the same 2.9L Powertech 3cyl.
You'll find that the 2.9L 3cyl Powertech engine is one of the best tractor engines made.
That being said, I wouldn't be concerned much. There are a LOT of members on TBN here that run this engine, I'm sure they can chime in with similar thoughts.
:thumbsup:
   / New JD 5055e Normally This Cold Natured? #3
My JD 5303 is the same way. Had the same 2.9 in a 5105 that was not turbo that cold cranked much easier. I cranked mine at around 40 degrees last weekend. I use the intake heater and it does run a little rough for a few seconds.
   / New JD 5055e Normally This Cold Natured? #4
Never had an issue with mine. use the heater as needed
   / New JD 5055e Normally This Cold Natured? #5
My 5045d is a little cold blooded under 45° or so...once it warms up, never an issue.
Sent from my LGL35G using TractorByNet
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
