New JD 4520 Pictures? Hopefully
   / New JD 4520 Pictures? Hopefully #1
xrjohndeere
Mo
2021 Kubota L4060 HST
Hopefully this worked. I loaded some pictures of my new tractor with my 448 backhoe mounted that John Deere said would not work. The tractor is new. The loader and hoe was kept from my old 4520. I had to modify the brackets to make them fit the new cab tractor. Now all I have to do is install my stereo and I will be set.
   / New JD 4520 Pictures? Hopefully #2
Looks like you're ready! Is the rear glass out for the backhoe?
Also, check your heater hoses where they enter the cab column at the bottom of the cab. Mine were chaffing on the metal and had to be wrapped in nylon.
Pete
   / New JD 4520 Pictures? Hopefully #3
Great looking tractor. Time to have some fun. Enjoy. :thumbsup:
Yes I took the glass out so I could reach in and move the loader from the back. The glass comes out real easy. Thanks for the heads up on the heater hose.
   / New JD 4520 Pictures? Hopefully #5
Fine looking tractor. The 4520 is a good machine. Enjoy and be safe
   / New JD 4520 Pictures? Hopefully #6
Good for you:thumbsup::D
FWIW, since the loader valve is so close to your seat position it would be interesting to see if you can connect to the valve from the rear to gain access. Second I would say look at a JD110 tlb, if you could add the two switches for repositioning ie the forward reverse switches that would be cool. In your case it would eliminate the need to have the window removed.
My only concern would be that in a 110 you are inside of the rops while operating and in your case you are exposed.
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
Electric Concrete Mixer (A51573)
Electric Concrete...
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
2010 Chevy Silverado HD Crew Cab (A52384)
2010 Chevy...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
