New Iseki owner
   / New Iseki owner #1
texashd4x4
Texas
Iseki TL 2100
Hello all, I just traded a zero turn mower in for an Iseki TL 2100. It seems to run and drive great. I have ordered new air, fuel and oil filters for it and flushed the radiator. I have read several post on here and now alittle nervous about my trade. Does anyone know about the TL 2100? I didn't get any info on the tractor and do not have a user manual. Any comments would help. Thanks.
   / New Iseki owner #3
If I remember correctly, the hydraulic filter can be washed out and reused. If the hydraulic oil hasn't been changed since it hit our shores, I would suggest changing it also. The injection pump also has a drain and fill port.
   / New Iseki owner
Thank you. Do you have any idea where the hydrolic filter might be? Also where the injection pump is?
   / New Iseki owner #5
I have a TL2300 which is the same basic animal. The hydro filter is there on the bottom, I believe right side toward the rear side of the engine. It looks like an oil filter. In fact it is right next to the engine oil filter only larger.
The injector pump is on top of the engine towards the side with a bunch of plumbing going in and out. IT DEFINATELY needs to have the fluid checked, changed, a filled on a regular basis. Havent got time to look; but there is an excellent post on here as to how to do that. Search for:
http://www.tractorbynet.com/forums/iseki/123503-injector-oil-change.html
http://www.tractorbynet.com/forums/iseki/108185-injector-pump-oil-change-clutch.html
http://www.tractorbynet.com/forums/iseki/76323-fuel-pump-oil.html
There is another one but I couldnt find it where a guy took some really good pics of doing this and the 2 bolt looking plugs on the side of the pump..........Good Luck.......Dennis
   / New Iseki owner
Thank you. I thought the filter next to the oil filter was the fuel filter, and ordered one. Gues I'll be looking for the fuel filter location now. I will check the injector pump too. Thank yall again.
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2022 LOAD TRAIL GOOSENECK TRAILER (A52472)
2022 LOAD TRAIL...
HYSTER H60XT FORKLIFT (A52472)
HYSTER H60XT...
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
2025 Chery 7ft 18 Drawer Workbench (A50325)
2025 Chery 7ft 18...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
