New Holland's Casting Breakage Problem
   / New Holland's Casting Breakage Problem #1
MeBuyIt
Erie, PA
none
There were many postings concerning block/bell housing casting breakage problems on
NH tractors, i.e., TC30, etc. So, can someone can answer this question:
Was the mount point casting breakage a defective casting problem on some
NH tractors, or is there an inherent design problem with the FEL mounting
directly to the casting on the NH tractors?
Thanks for your help.
   / New Holland's Casting Breakage Problem #2
I think most of the problem was caused by loose bolts on the loader and on the belhousing and exceding the tractors lift capacity. If you think about the number of these tractors with loaders that have had no problems the % of tractors that had problems is minimal.
Bill
   / New Holland's Casting Breakage Problem #3
I agree with Bill. Most of the problems have been preventable. Only a few have happened during normal operation and with all bolts tight. We all tend to overreact when we see a failure because that's a nightmare scenario. I have seen a few uncalled for failures that are horrible. I've heard rumors of many more failures without specific supporting info or pictures. I don't think the New Holland tractors have any more problems than similar sized tractors of other brands.
I can think of a lot more things that might stop me from buying a New Holland compact at this point. The biggest is that New Holland no longer sources compact tractors from Shibaura, but they still have to get spare parts from them. Shibaura seems to think that they will make New Holland regret its decision by increasing the price of spare parts by 200% to 300%. To me, that is a far more justifiable reason to be concerned when buying a used New Holland. I'd feel the same way about buying a John Deere/Yanmar model. At the current time, I think I'd want a tractor built in a factory with the same name as the seller. Larger New Hollands, John Deere built compacts, Kubotas, Kiotis, Mahindras, and Masseys all seem to have models built in their own factories. To me that's a valid consideration.
   / New Holland's Casting Breakage Problem #4
The frame problems I have read about seems limited to the TC 30 and 33 with the 7308 loader.
There was a long thread on this problem on the Tractorpoint.com site . (sorry I don't know how to post a link)
Several owners there have had this problem with the TC 30/33.
It appears like the 7308 loader lacks the support bracing needed and is causing frame break problems.
   / New Holland's Casting Breakage Problem #5
Guys, the TC33, TC29, and some other similar compacts do not have a subframe. For the 7308 loader on the early Class II Boomers to the 14LA/15LA loaders on the later Class IIs, there is no sub-frame whatsoever. Of course this limits the lift capacity. However, when a person installs a quick attach plate and pallet forks, they can drag much more weight off a flatbed on a pallet than the loader is rated to lift. The same can be true for a 4-N-1 bucket or many other ways of getting more weight on the loader than the loader could lift from the ground.
In New Holland's system, the system relief valve is only in the loop when the loader joystick is not centered. The joystick may have an emergency relief, but it will be way over the rated lift value the same as the one on the 3PH. The main system relief valve that is set to about 2200 psi is isolated from the loader because the joystick is centered. Now, once the joystick is centered, you can drag enough load off a flatbed truck to put severe strain on the tractor, especially if you have a backhoe attached or lots of rear ballast. In effect, you are bending a 'popsicle stick' and hoping it won't break in the middle. This is a danger with any tractor, but much more so because many small compact tractor owners just don't take all these things into consideration. There are tremendous dynamic forces applied to our loaders and tractor frames when we are transporting a load near the limit and hit a bump. Without a sub-frame, the shock load goes directly to the housing where it loader bolts into. If any bolt is loose, the others have to take even more shear force than normal.
Is that what happened in all the reported cases? Who knows. DK35Vince, you posted about a problem discussed on TractorPoint. I went there and found a thread that started way back in 2002 about a 1999 model tractor. That's almost a 14 year old tractor and a 10 year old thread. They don't even make that configuration of tractor/loader anymore. What I mean by this is that if you look back in almost any tractor's history, you will find some problems and failures that should not have occurred. You'll also find a lot of discussion and finger-pointing without real knowledge of exactly how the system works or what exactly happened. Many of these tractors that failed were bought used. How can you ever be sure a used tractor has not been abused?
So yes, New Hollands have had some failures, but I think it is wrong to say that New Hollands are failure prone. Are there better designs? Of course there are. Do other manufacturers configure their tractors the same as New Holland without subframes for their loaders? Yes, many/most do on some models. These are all considerations we need to discuss and compare before making a buying decision. They go right along with discussions of how much tractor we need and what we can afford. For many, getting as much tractor as we can afford is more important than what we decide to do with that tractor once it's in our garage. If you asked for a show of hands of people who have abused their tractors, I'd have to be sitting here with both hands in the air.:ashamed: Luckily, my tractor has a big subframe that I paid for by buying a more expensive tractor. It has protected me when I wasn't protecting my tractor, if you know what I mean.:rolleyes:
   / New Holland's Casting Breakage Problem #6
Did you read the whole thread?. Its 23 pages long with multiple cracking issues.
Yes, the Tractorpoint discussion was started in 2004.
But it is an ongoing discussion. There were more members reporting it happened to their machines at the end off the discussion posted in 2012/13.
All the problems I saw were on older models with the 7308 loader
   / New Holland's Casting Breakage Problem #7
Common denominator is a smallish utility loader tractor without sub-mount and using them like dozer. Dynamic loading like Jim expressed is huge and no one talks about that.
   / New Holland's Casting Breakage Problem #8
Seems odd that its the same model/loader combination time and time and time again.
New Holland is a fine machine.
But personally if I was looking at used machines I would avoid any TC 30/33 if it had the 7308 loader
   / New Holland's Casting Breakage Problem #9
Have a TC 30 that I purchased new in 2003 with a 7308 loader and also a 757c backhoe on it . Have not had any issue's that have been relayed here and on other sites . Even though I asked here in those threads and on other sites , No one said if it was a HST model or a manual transmission type tractor . Some of the threads I read , the owner also had a backhoe but never stated if it was a sub frame mount or 3 point mount .
As stated above , over loading the FEL can be an issue , But also when attaching a backhoe , by over tightening the top link puts way to much torque back into the housing , thus literally cracking the tractor in half . I personally think the issue is people buying that size tractor both dollar wise and size wise , then trying to use it as a tractor twice it's size .
Fred H.
   / New Holland's Casting Breakage Problem #10
I've also wondered about this breakage problem.I have 2007 TC30 with the 7308 loader, well pleased with it.Checked bolts for loader brackets,no problems.
QA 72" Rock Grapple Bucket (A44502)
QA 72" Rock...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A44789)
2014 Yale 3 stage...
AGT QA Auger (A44502)
John Deere 755C Series II Crawler Loader (A44391)
John Deere 755C...
YANMAR SV08-1A (INOPERABLE) (A45333)
YANMAR SV08-1A...
2015 FORD F-250 (INOPERABLE) (A45333)
2015 FORD F-250...
