New Holland TZ24DA steering wheel removal help
   / New Holland TZ24DA steering wheel removal help #1
vwztips
NH TZ24DA
Need to access the fuel pump behind the cover for the steering wheel column.
This means the steering wheel needs to come off. I have removed the nut and attempted using a gear puller but wheel won't budge and afraid of breaking the wheel.
any tricks to get the steering wheel off?
   / New Holland TZ24DA steering wheel removal help #2
Welcome to TBN!
No tips other than penetrant and a very little amount of heat on the steering shaft. Lift up on the wheel while pulling on either side to loosen. The puller is the only way.
   / New Holland TZ24DA steering wheel removal help #3
Plus a liberal application of PBlaster where the nut was and let is sit for a couple hours.
PTO Power Shaft (A49251)
PTO Power Shaft...
2014 FREIGHTLINER CASCADIA DAY CAB (A45678)
2014 FREIGHTLINER...
78in Bucket (A49251)
Mini Skidloader 44in Bucket (A49251)
Mini Skidloader...
2012 DODGE RAM 5500 HD SERVICE BODY (A45678)
2012 DODGE RAM...
3pc 14 inch Premium Diamond Blades (A46684)
3pc 14 inch...
