New Holland TS115A
   / New Holland TS115A #1
prestage601
2004 TS115A deluxe
I am a Newby I have a New Holland TS115A that starting going to Neutral about every 30 ft but if you keep your foot on clutch petal holding it about an inch from top it will run all day, has anyone had this problem or maybe could help me figure out what might br the problem. I have unhooked the parking brake because it was frozen and holding brakes and put a new little switch under the clutch petal called a hyclometer ? or something along that line but the problem still exist.
   / New Holland TS115A #2
A little shy on information here,
assuming that you are a power shuttle with forward-neutral-reverse on the column and a foot pedal that looks like a clutch;
which will have a POTENTIOMETER Assembly and also a switch which they will call a Push Switch
Yes that is correct it is a power shuttle with forward and reverse on column and a petal that is very easily pushed and yes that is the part I put on and problem is still there. Any help would be greatly appreciated.
   / New Holland TS115A #4
It sounds to me without being able to see it like that switch may need to be adjusted?
When you push the pedal down an inch your tractor works properly?
With the pedal pushed an inch is it activating that switch?
When you unhooked your parking brake is there a switch for that?
The tractor could be looking for the parking brake switch, and the clutch switch, as well as the potentiometer.
Also when did this issue start occurring.
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
2020 DRAGON ESP...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
Hyster Forklift (A55973)
Hyster Forklift...
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
