new holland ts100 problem
   / new holland ts100 problem #1
faz192
warrnambool, vic
new holland t7080
I have a ts100 and the linkage light flashes when the clutch pedal is held in.
I have checked draft pins and
potentiometers both target and actual
have cleaned earth points from linkage cover to cab and the earth point behind the left hand console cover
any suggetions
   / new holland ts100 problem #2
G'day Faz does it give you a code type flash i.e 2 flashes pause then 3 flashes would be code 23? If it does then come back with the code . I am in Ararat and I will have a look in my book tomorrow when I get to work.
Jon
cheers I will have a look tomorrow
there is no sequence to the flashes it only seems to occur when the clutch is full depressed for about 5 seconds it triggers switch or bottom of clutch switch any help would be appreciated
   / new holland ts100 problem #5
G'day faz I can't find anything in my book as to your fault, does it stop the tractor from operating at all? Sorry i"m not much help
Jon
it just stops the linkage from working until ignition is cycled then works ok again until clutch is held down again
2014 Chevrolet Cruze (A51694)
2014 Chevrolet...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
