rodgerm140
My TN75DA has been to the dealer as a result of Power Shuttle Problems, for no obvious reason when you engage the shuttle it will momentarily attempt to move forward or reverse and then appear to go into neutral. It does not throw any codes but the dealer has replaced the PCM, a diode, the seat switch and calibrated the PCM, it worked find after I got it back then today it was back to the same trick. I shut the tractor off for about an hour then went back out and started it up and it worked fine, sofar I have spent about $3000.00 on the problem which appears to not have been fixed. I will be calling the dealer in the morning but wondered if anybody else has had this problem? Thanks, Rodger
