New Holland tn70A won't accelerate
   / New Holland tn70A won't accelerate #1
winston1
Super Member
gilmer tx
Bobcat CT235
not mine but belongs to neighbor. He has changed fuel filter, bled at injectors, fresh fuel, air filters clean. Will idle but won't accelerate. lot's of white smoke. Wondering if it could be turbo problem? :confused3:Any ideas would be appreciated.
   / New Holland tn70A won't accelerate #2
Check fuel flow from the tank then check the banjo fitting at the fuel lift pump inlet side for trash in the tube, fitting and bolt. Check the screen in the top of the lift pump. If that all checks out, check the lift pump for proper fuel delivery. If that all checks out the injection pump becomes suspect.
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
71063 (A49346)
71063 (A49346)
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
