New Holland TN70A 2007.engine cut-out electromagnet 5 amp fuse keeps blowing
   / New Holland TN70A 2007.engine cut-out electromagnet 5 amp fuse keeps blowing #1
TMarble
Conesus, New York
New Holland TN70A
I have a New Holland TN70A 2007. The engine cut-out electromagnet 5 amp fuse keeps blowing out. The first time I replaced the fuse I ran tractor for about 8 hours with no issues. Next day I started tractor and in started right up, ran for a few minutes then blew fuse and shut down. Replaced fuse again and it started up ran for a minute then shut down. Replaced fuse again started up and ran good. Used for about 2 hours with no issues. Any help would be greatly appreciated.
TMarble NY
   / New Holland TN70A 2007.engine cut-out electromagnet 5 amp fuse keeps blowing #2
Check the electromagnet for an internal short. Check the wiring going to the electromagnet. Try running a separate jumper wire with a fuse in it to the electromagnet. If that fuse also blows then you know the problem is in the electromagnet and not the wiring.
Thank You. I will do those checks.
TMarble
2853 (A51691)
2853 (A51691)
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2018 Bobcat T870 Skidloader (RIDE AND DRIVE) (A50774)
2018 Bobcat T870...
Kubota SVL95-2s (A50120)
Kubota SVL95-2s...
1999 24DTA pintle hitch trailer (A52748)
1999 24DTA pintle...
2006 CIMC SZJ9341TJZ03 20FT CHASSIS TRAILER (A52141)
2006 CIMC...
