new holland tn65 won't pull
   / new holland tn65 won't pull #1
horsey3485
robertsdale alabama
tn-65
Good evening.. I have a 2002 tn65 that when you shift to forward or reverse engine runs but wont move. you can lock diff and right wheel pulls but left will not pull. any thoughts or suggestions.
   / new holland tn65 won't pull #4
I've seen/fixed a few. Done more of the 35 series/ early TL's though. Braking hard on one side when one wheel spinning or the difflock engaged does them in quickly. Fairly easy fix, relatively speaking.
Thanks, looking at pictorial seems logical, we were moving hay in feed lot a lot of slipping and braking to swing tractor around to get out.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2013 MACK CXU (A52472)
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
2015 Peterbilt 320 Truck (A51692)
2015 Peterbilt 320...
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
