NEW HOLLAND TN 70 CODE 42
   / NEW HOLLAND TN 70 CODE 42 #1
JTM
I DROVE MY TN 70 UPON MY TRAILER AND WHEN I STARTED IT TO DRIVE IT OFF, IT WON'T GO FORWARD OR BACKWARDS. CODE 42 IS SHOWING AND I UNDERSTAND THAT IS ELECTRICAL. ANY IDEAS WHERE I COULD START CHECKING THIS OUT MYSELF??? ALSO, WHERE CAN I GET THE MOST RESONABLE PRICED REPAIR MANUAL ON THIS THAT DOESN'T COST $100'S OF DOLLARS. NEW HELP ASAP!!!!!!!!!!
   / NEW HOLLAND TN 70 CODE 42 #2
Fault code 42 'A' Clutch Pack PWM solenoid or ECM driver short circuit to 12 volts.
Faulty wiring between ECM and Clutch Pack A solenoid.
OR, Faulty A Clutch Pack Solenoid
Or, Faulty ECM
The transmission section of the relevant service manual for your tractor has the fault codes, troubleshooting flow charts, and harness connector pin locations. The electrical section has the schematics, of course. As far as I know, the sections can be purchased separately. The only repair manual worth owning is published by New Holland. Check ebay for cheaper ones, but know EXACTLY what you are buying, preferably by document part number.
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
1999 MATE END DUMP TRAILER (A52472)
1999 MATE END DUMP...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
