New holland td5050 need help
   / New holland td5050 need help #1
Tnc15
New Holland
Hi all. Thank you for this site!! Needing some help in understanding this shuttle. I parked the tractor after plowing a field and when I tried to move it the next day I couldn’t get it in forward. It will go into reverse just fine. I check the hydraulic fluid in the rear case and it is at the appropriate level. I looked up in the linkage from underneath and didn’t see any linkage that has come apart. Anyone have any pictures of the manual. I appreciate any help I can get. Trying to get 4 more fields disked before the rain comes in south Texas. Best Regards Mike
   / New holland td5050 need help #2
Welcome to TBN!
I assume it is a Power Shuttle transmission. If so, possible shuttle lever problem
2003 MACK 1M2 DUMP TRUCK (A60430)
2003 MACK 1M2 DUMP...
2006 Trail King RGN 45ft. Heavy Haul Lowboy Equipment Trailer (A60460)
2006 Trail King...
Kubota M108S (A53317)
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Deere 35G (A53317)
Deere 35G (A53317)
