New Holland TCE
   / New Holland TCE #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
These are the Italian NH compact tractors on the left, it looks like you can get a factory cab on these models. I wonder if they will bring them over to the US, they are models TCE40, TCE45 and TCE50.
Front 3pt hitch is a nice feature for a compact.
   / New Holland TCE #2
cab comming this fall when the tc50 is introduced on that model only so far
   / New Holland TCE
Is the TC50 going to look like these or is this the TC50 just introduced in Italy first, also the first picture looks like a smaller TC with a factory cab.
   / New Holland TCE #4
Italy's New Holland TCE Compact Tractor Series
<pre>
Modello TCE40 TCE45 TCE50
Motore (tipo) Yanmar Yanmar Yanmar
Potenza (ECE R 24-03) (kW/CV) 25,2/35 29,5/40 33,2/47
Regime nominale (giri/min) 2800 2800 2800
Coppia max. (ECE R 24-03) (Nm a giri/min) 103 a 1800 120 a 1800 135,8 a 1800
Numero cilindri / Aspirazione 3 / Nat. 4 / Nat. 4 / Nat.
Cilindrata (I) 1,624 1,995 2,189
Raffreddamento ad acqua Standard Standard Standard
Emissionato Fase 1 Fase 1 Fase 1
Capacità carburante (I) 40 40 40
Trasmissione TCE40 TCE45 TCE50
Diametro frizione (mm/in) 225/9 225/9 225/9
Trasmissione base 12 x 12 12 x 12 12 x 12
Trasmissione con superriduttore optional 16 x 16 16 x 16 16 x 16
Tipo inversore Sincronizzato Sincronizzato Sincronizzato
Velocità max. (km/h) 30 30 30
</pre>
Robert...
These look like orchard/vineyard units, not only width but especially the front mounted rops...
Of course New Holland TCE has a super direct injection engine... Yanmar... /w3tcompact/icons/grin.gif
And also notice hydrostatic is not even offered... like the front mounted pto is very European... as is gears {in Orchards}... /w3tcompact/icons/wink.gif
   / New Holland TCE
But do you think these are what the new TC50 is going to look like. I doubt the US tractors will have a front 3pt hitch of pto and the rops will be moved back but the tractor itself should remain unchanged I would think. Can you tell what model it is in the first pic with the cab?
   / New Holland TCE #6
Remember the Fiat-Hesston’s from the 80’s… here’s New Holland 2002…
Purpose designed cab {England’s TC series}
Extremely spacious for this size of tractor, the fully glazed cab has a large glass area for truly panoramic visibility. Purpose-designed for the TC27D, the cab protects the operator from noise, dirt and the elements, ensuring year-round comfort. Cab accessories available include radio cassette, rear wash wiper, front and rear work lights and a flashing roof mounted beacon. In addition to the cab’s forced air ventilation system, the front and rear windows open to provide extra ventilation. The fully glazed doors open wide for easy access and provide excellent visibility to the sides. Controls are ergonomically laid out and labelled for ease of use and operation, just like a full size tractor.
TCE Series
Series TCE tractors
Purpose designed to meet the needs of smaller farmers and specialist growers, the New Holland Series TCE agricultural compact tractor range combine ease of operation and rugged build with modern ergonomics, advanced styling and excellent operator comfort. Three TCE models are available, the TCE 40, TCE 45 and TCE 50. All offer established New Holland performance features that include an outstanding 55 degree turn angle for the driven front axle, a two speed 540/540 Economy PTO and a generous 1200 kg rear linkage lift capacity. A 12x12 forward and reverse speed 30k/h transmission is standard, a 16x16 creep speed variant offering operating speeds down to 250m/h also being available.
<pre>
Model Engine Power Kw/Hp
TCE 40TCE 45TCE 50
27.2 / 3731.6 / 4336.1 / 49
MANUFACTURED IN ITALY
</pre>
   / New Holland TCE #7
Robert,
Are you sure it will introduced as a TC50... or TCE50...?
Going around the world, it appears the entire TCE line uses Yanmar engines, but I highly suspect they may be missing from the TCE line intro'd into the US... but maybe not?
If you also look closely at the Landini Compact Orchard/Vineyard models with Yanmars... they have a similarity to the NH TCE series...
The "Made in Italy" is sure building up a good reputation with me... /w3tcompact/icons/smile.gif
   / New Holland TCE #8
Running a mower using a front 3pt hitch and PTO would sure be nice! It would be great for bush hogging thick brush – to be able to mow the stuff down first instead of driving over it first would be a big advantage. The front 3pt hitch would be much nicer for pushing snow with a grader blade too. I don't see the logic behind the mid mount ROPS though, except for a convenient place to mount a rear view mirror. I like the bigger front tires.
   / New Holland TCE #9
There are currently tc50's in the US being tested by New Holland at undisclosed locations. We are told everything looks good and should be ready for dealership deliveries this fall. The pictures we have seen shows the cab just like the picture of the tc27 in england as posted above. The engine will be just like all the others here in the United States not a yanmar.
   / New Holland TCE
I was assuming it would be to match the rest of the line. Thanks for the rest of the info.
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
New Holland TS100 Tractor (RIDE AND DRIVE) (A50774)
New Holland TS100...
2022 CATERPILLAR 305CR EXCAVATOR (A51242)
2022 CATERPILLAR...
Toro Z-Master 7000 Series 70in Zero Turn Mower (A50322)
Toro Z-Master 7000...
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
2009 Etnyre & Co 4" Rear Discharge Hot Oil/ Asphalt Tanker (A47384)
2009 Etnyre & Co...
