New Holland TC55DA EHSS
   / New Holland TC55DA EHSS #1
Twistedgrip
Two issues... 2006 New Holland TC55DA w/EHSS
(1)Anyone had issues with the brake safety switch not working even when bypassed? My brake safety switch when applied is supposed to allow the operator to dismount the tractor while the engine is running. It started operating sporadically and then just stopped working at all. I removed it, cleaned it best as possible (since it doesn't come apart) and it still doesn't work. I tried a temporary jumper to see if that would work and it still does not work. NOW the glow plugs don't work. Does anyone know if these may be related? The glow plugs are activated by the ignition key prior to start up. The light will come on and then go out but I do not hear the familiar "click" when the turn off. Can these two problems somehow be related?
(2)I am preparing to make a set of lower lift arms since I inadvertently bent (BROKE) one of mine while getting tangled up on a stump while using the front end loader while turning around. New Holland wants $700 each for new ones. (The tractor gets abused every now and then) My question is... what steel has everyone been using to make new lift arms out of? I don't want it too strong or I will end up tearing up something else but I don't want it too soft either or I'll end up making several sets. Suggestions...
   / New Holland TC55DA EHSS #2
Check the safety switch under the seat and the PTO safety. Since the glow plugs don't come sometimes, check the ignition switch too.
I've checked all of the switches and the only one that isn't working is the brake switch. Should this keep the glow plugs from functioning? I don't think so because they worked before without using that switch. I'm suspecting either the glow plug itself or some logic in some controller somewhere. I replaced the main safety switch a few years back due to it going bad (EXPENSIVE!!!) and hope it's not playing a role in this issue. I'm just keeping a can of ether close by to start it cold and once it's warm it starts fine. I do wish it was a 75 hp tractor though...
   / New Holland TC55DA EHSS #5
Lifting arms are mostly C35 or C45 Steel and also GGG40 Graded Casted Iron. If you send me some photos, I may support you in finding correct parts.
Parker 4000 Gravity Wagon (A50774)
Parker 4000...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
10 x 18 Transfer Auger (A50515)
10 x 18 Transfer...
2011 Isuzu NPR Box Truck (A50323)
2011 Isuzu NPR Box...
2009 Lexus RX350 (A50324)
2009 Lexus RX350...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
