New holland Tc40da no start
   / New holland Tc40da no start #1
csmoak25
Waycross, Ga
New holland TC40da
Wanted to share my fix with my no start no engine turn over
The white wire furthest to the right on the back of the ignition plug in that goes to the small pink wire on the starter solenoid Somewhere between the two ends it was dropping voltage and not enough to make the stsrter turn the engine at all. I spliced In to the back of the ignition into the white wire and run it through the hole where the throttle cable runs out the engine and then tied it into the pink wire on the starter!!!!
Only thing I can tell right off that it bypassed was allowing it to be started in gear
Will keep you posted if I run into any issues
   / New holland Tc40da no start #2
I'm not sure how different they are but on my 2220 (34DA) a connector underneath, in front of the left rear axel connecting to main case gets yanked out by brush every once in a while. I never even bothered to see what it is (neutral or pto?? It will keep running after , just wont restart unlike the seat switch which will kill it all together.
Brian
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
74in FEL HD Round Back Bucket (A51039)
74in FEL HD Round...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
