New Holland TC40D. Won't turnover
   / New Holland TC40D. Won't turnover #1
JWG1
Middleport, NY
TC40D
I have a 2001 New Holland TC40D. Started, ran fine and brush hogged with on Saturday. Went to start it on Sunday the instument panel lit up, the glow plug indicator worked but when I turned the key to start the instument panel went out and and nothing. Checked the fuses all appeared OK, replaced the battery and cleaned terminals, still nothing. Any ideas?
   / New Holland TC40D. Won't turnover #2
I have a TC30 and had the same thing to me when brushhoging, A wire under where the cluch is came off,look under the
tractor and see if any wires are came a part.
good luck
scott
Thanks I"ll check it out when it stops raining.
2014 International Durastar 4300 Terex BT2047 47FT 10 Ton Crane Truck (A50323)
2014 International...
Case 480E (A50120)
Case 480E (A50120)
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
Horsch Joker RT32 Speed Disk (A50514)
Horsch Joker RT32...
