New Holland TC40D Reset Switch
   / New Holland TC40D Reset Switch #1
Windyacres
Is there an emergency shutdown switch that needs to be reset after safety shut down. If so where is it located?
   / New Holland TC40D Reset Switch #2
I'm not sure what you mean by a "safety shut down," but the TC40D doesn't have any sort of "Master Reset." To start, though, make sure you're in N, have the brakes applied, and don't have either PTO activated.
You might want to check under the tractor for any loose wires, though. I once shut down my TC40D, and couldn't get the thing to restart, no matter what. When I looked underneath, I saw a wire connector had been pulled loose, and upon figuring out where to plug it back in, the tractor started right up. If you're doing everything normally, and the tractor won't turn over, I'd start looking for some dangling wires.
- Jay
   / New Holland TC40D Reset Switch #3
I also believe there is a main fuse located near the starter although I have never heard of one blowing.
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
