Oil & Fuel New Holland TC34DA Fuel Quantity indicator problem
   / New Holland TC34DA Fuel Quantity indicator problem #1
mac1520
Swoope, VA
2008 New Holland TC34DA
Hello, I bought a New Holland TC34DA Compact tractor that has 440 hrs on it. It's been working great, but noticed a few weeks ago the fuel qty indicator is becoming erratic. Seems like it's electrical because the gauge will read fine one minute and then drop to zero the next. Usually takes a while for the tractor to warm up before it stays where it should be. Is there a relay/switch I can replace? Any info would be greatly appreciated.
MAC
Update: Doing some research last night found the manual describing Fuel Sending Unit that mounts on top of fuel tank. Removed instrument panel and found a screw loose that was connected to fuel sending unit. Tightened screw and good to go!
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
40' Sea Container (A50774)
40' Sea Container...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
1980 AM General M35A 2.5 Ton 6x6 Cargo Truck (A50323)
1980 AM General...
