New Holland TC33 Control Arm Broke
   / New Holland TC33 Control Arm Broke #1
WBowhunt
On My 3pt I went to raise the 3 pt arms and noticed that the Hydrolic pump was not shutting off when the arms reached the top. I had to push the lever back down some to get the pump to stop. I went to look at the Control arm to see the adjustment had come loose and found the control arm was actually bent and cracked at the base. I ordered a new arm and assoc. parts. But first I can not firgue out how to get the roll pin out. Where is it located I am not sure I can get a Drift punch in there. But more importantly. I am concerned that if I put a new arm on that it may do the same if something else is wrong. How hard should it be to manually move the Control arm? When disconnected from the arms, should I be able to move it by hand? I can get it to moce some with a pipe wrench on ( Just wanted to make sure it was not Seized up) and it does move some, but it is pretty stiff. Is that normal?
OK, After removing the tool box bracket and the Lower ROP Support Bracket, I was able to get in there with a Drift punch and get the roll pin out. But I can not seem to get the Control Lever off. I have sprayed with some WD-40. I am still concerned that the control lever system seems rather stiff, so even if I get the broken control lever off, and put the new on, will it just bend and break again. Anyone have any experience with Replacing the 3 pt control lever?
   / New Holland TC33 Control Arm Broke #3
I am having the same issue with my tc40. What did you find out?
12 Misc Printers (A50325)
12 Misc Printers...
MI T M 1400 PSI Electric Pressure Washer (A50325)
MI T M 1400 PSI...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
4 Balance Boxes Adjustable Mounts and Misc. Monitor Mounts (A50325)
4 Balance Boxes...
2015 KENWORTH T680 (INOPERABLE) (A52472)
2015 KENWORTH T680...
