new holland TC30
   / new holland TC30 #1
vjwillsey
eldorado, il
hew holland TC30
I just replaced the fuel filter (low power and dies). Also bled fuel lines to injector pump and the injector lines to the cylinders. The problem is that the tractor runs fine for few minutes and then loses power and dies. Bleed the lines again and then runs and dies as before. Is there another fuel filter somewhere?
   / new holland TC30 #2
I have had occasion with my TC18 that there was quite a lot of water that had condensed out in the fuel tank, and it took two tries to get all the water out of the sediment bowl. You might try draining it again.
Guy.
   / new holland TC30 #3
I am having the same problem with a customers tractor. Was running fine until he changed the filterelement. I bleed the air out at the pump, and bleed at the injectors. I will start & run for about
30 seconds then die. Bleed everything again & runs for 30 seconds & dead. I pulled the line off at the
injection pump & has good steady flow. I filled a pint jar ok. Pulled the fitting going into the pump that
has the bleeder valve on it. Was clean & no obstructions. Think maby some crud got into the pump.
Any ideas...
Jim
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
