New Holland TC30 What size finish mower?
   / New Holland TC30 What size finish mower? #1
Fabriktr
Collinsville
New Holland TC30
I have a TC30 and would like to run a 6' wide 3 point mounted finish mower. Is this too big or do I need a 5'? The engine is 30 hp. HST drive and the rear PTO is rated for 24 hp.
   / New Holland TC30 What size finish mower? #2
6 ft is the most common for a 30 hp tractor. Ken Sweet
   / New Holland TC30 What size finish mower? #3
I used a 6-footer behind my TC30 when I had it. Worked fine. I'd consider a 7-footer if your grass isn't terribly thick or tall.
   / New Holland TC30 What size finish mower? #4
I ran a Woods PRD 7200 behind my NH 1720 for 8 years with no issues...
sweettractors, bspeedy, Turbys_1700, Thanks for the info. I can source a 6' locally from Tractor Supply for $1599. The 5' is $1399. I will get the 6' based on your recommendations. The extra $200. seams like a no brainer. That extra foot should pay for itself rather quickly with less time spent mowing, less time on the engine, less fuel, yada, yada. I have been searching Craigs List for a used one, but the selection is meager at best.
   / New Holland TC30 What size finish mower? #6
Any chance I (we) can talk you into a good second hand Bush Hog or Woods mower instead?
At least check the parts supply for the TSC mowers. Tell them you have a 15-year-old mower from them and see if parts are available - as a test. I can assure you that Woods and BH will have parts for you many years from now.
bspeedy, Thanks for the offer. I have covered the finish mower acquisition. I found a good used John Deere 6' mower and bought it.
   / New Holland TC30 What size finish mower? #8
Certainly a good choice. JD is known for their parts availability. Go through that machine carefully and repair anything not up to snuff and I'm sure it will treat you right for many mowing seasons to come.
John Deere 6105D (A50120)
John Deere 6105D...
(INOP) VERMEER V1350 WALK BEHIND TRENCHER (A51244)
(INOP) VERMEER...
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
John Deere 693 Corn Head (A50514)
John Deere 693...
2015 CATERPILLAR 303.5E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
