stevegay
I have a 2003 New Holland TC29D that will only start if I boost it off or bypass the ignition switch and connect the start solenoid directly to the battery. The starter/solenoid, battery, and key switch are all new. I used another battery (instead of the new one) just in case the new battery was bad and it still wont crank. I have swapped relays 1, 2, & 3 around, cleaned the terminal strip where the relays connect, and nothing helps. After boosting it off, it will crank one or two times after disconnected from the boost battery but if it sets for a few minutes, it wont crank. I can hear the start solenoid hitting, but it wont engage the starter motor except under the conditions described earlier. I have also cleaned the connection where the negative batter cable is bolted to the frame. Any help would be greatly appreciated.
