New Holland TC29D accelerator boost pedal not working.
   / New Holland TC29D accelerator boost pedal not working. #1
PDobson
New Holland Boomer TC29D
My accelerator boost pedal on a TC29D is not working, no change in the engine RPMs when stepping on it. Any assistance on causes and repairs is greatly appreciated, thanks.
   / New Holland TC29D accelerator boost pedal not working. #2
Follow the linkage from the pedal up to where it connects to the throttle linkage. Look for any loose or disconnected attachment points.
It's a very simple set up.... some tractors use rods, some cables, some both. That's where to start looking....
Thanks for the reply, will trace the linkage.
   / New Holland TC29D accelerator boost pedal not working. #4
I had a TC33D and it never had a "boost pedal". Where is it located and how does it work with a hydro trans?
I have a manual transmission, it is located basically where your hyrdo transmission accelerator pedal is located, on the right side by the brake pedals.
Update, did as you suggested, found that the cable ball end had come out of the bracket to the accelerator. The set screw had worked its way lose, threaded it back on and stayed in place. Big thank you!!
   / New Holland TC29D accelerator boost pedal not working. #8
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
MACK DUMP TRUCK (A59823)
MACK DUMP TRUCK...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
KUBOTA M900 TRACTOR (A59823)
KUBOTA M900...
