New holland tc27d issues
   / New holland tc27d issues #1
jonwhite
New holland tc27d
Hi, i have recently purchased my first tractor- a new holland tc27d roughly year 2000 (similar to the more modern boomer).
It has few issues but hopefully with some pointers from you guys i can get it working as it should.
1, The hst transmission works intermittantly - the oil is full.
2, steering column leaks fluid - i guess a seal of some discription.
There are a few more but i will be happier once these are fixed, any help will be gratefully accepted.
Thanks.
   / New holland tc27d issues #2
HST may have an air leak on the suction side
As far as the steering leak, it is the top seal on the steering motor. Don't use the seals that are recommended for the tractor as they are overpriced for what they are.
2005 Pierce Enforcer Special Operations Fire Truck (A50323)
2005 Pierce...
2022 Weber CR5-II HD Reversible Plate Compactor (A50322)
2022 Weber CR5-II...
LandPride RCF2072 (A50120)
LandPride RCF2072...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
2013 Ford F-150 (A50120)
2013 Ford F-150...
Vermeer 502 Towable Stump Grinder (A50774)
Vermeer 502...
