new holland tc18 down pressure?
   / new holland tc18 down pressure? #1
pepper1
Does anyone know if it is possible to get down pressure on the 3 point arms on a nh tc18? If so how can it be done? /forums/images/graemlins/confused.gif
   / new holland tc18 down pressure? #2
I don't know if it is or isn't possible (doubt that it is, but hey anything is do-able w/ enough time and money /forums/images/graemlins/laugh.gif), but given how light the tractor is, would it really do any good? It would probably just pick the back of the tractor up and then you've lost traction.
   / new holland tc18 down pressure? #4
Here's a Link to a previous TBN discussion about adding downpressure to a 3PH.
   / new holland tc18 down pressure? #5
</font><font color="blue" class="small">( Not possible )</font>
I think I'd phrase that as 'possible.. but not practicle'.
As other posts have atested.. an external hyd cyl on swivels on the lift arms.. mounted to an appropriate placed frame or brace somewhere abov the lift arms or lower lift arms would work.
I've seen an extra rocker arm welded onto one upper lift arm, and a ram attatched horizontally back to a frame on the tractor provide down pressure to an older tractor... very possible. Depending on what you have to work with, and how much welding and fabrication needs to be done.. could be anything from a few hundred bucks in a cyl and a bracket and an unused remote.. to 300-400 to add a spool.. etc...
Soundguy
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
2015 Ford F-550 4x4 Knapheide Service Truck (A48081)
2015 Ford F-550...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A48081)
2022 Chevrolet...
2024 iDrive TDS-2010H Pro Jack M2 Electric Trailer Jack System (A48081)
2024 iDrive...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
