New Holland TC 40 D
/ New Holland TC 40 D #1
Dirtmann
Elmwood, Ne
NH TC 40 D Foird 165 Kabota 2550 GST
Hello I am a new member and have a problem with the electric 2 speed. It keeps blowing the fuse. When the fuse blows I only have 1st and 3rd range. 2nd range is what I use the most. I have traced the wiring twice now and can't find a short in the wire. Has anybody had this problem and found a fix for this? Thank for any help with this. Dirtmann
/ New Holland TC 40 D #2
Is the actual range shifting mechanism jammed or in some way drawing too much amperage when you try to use it?
When I put in a new fuse it works for a while then the fuse blows. it seems that it works until it gets warmed up. Although yesterday I was going to drive down the road (already warmed up) so I put in a fuse and headed down the road in 4th range. It worked fine for about 1/2 mi. The fuse blew an I am in 3rd range. it seemed I hit a bump when the fuse blew. So this would make me think there is a short in the wiring somewhere. I haven't checked wire from fuse block to switch. I guess that will have to be my next check.
/ New Holland TC 40 D #4
