CJ4
Got my new T 4.75 in and on the invoice it's listed as having under Mid-mount valves.....mid-mount w/mec Joystick + div?? Ok so I understand the hyd set of connections on the loader is hooked to the mid valve and the button on the joystick when held down diverts the fluid to those connections, in my case will open/close the grapple. However, there is a 2nd button on my joystick that does nothing. Is this button available for another Diverter to run a 2nd set of lines and connections to the front of the loader like the first one was done? If so, is this function already there and just needs the lines ran or is this like adding a 2nd remote ie: I would have to purchase another Diverter valve to add to the mid mount valve to do this???
I want to add a tilt attachment to the loader. Their system will sell you a Diverter valve with an electric switch so you can flow thru or divert from their cylinder to like a grapple. However that requires running the wire in the cab etc that I dont want to do if I already have opportunities on my Tractor to accomplish this. Man, you could have things on your Tractor that you dont even know about for years. I need educating on what my Tractor has. Thanks for the help in advance!
