New Holland powerstar t4.75
   / New Holland powerstar t4.75 #1
navy315
Oswego, Ny
New Holland
I had bought a 2014 New Holland t4.75 Last fall. It has only has 48 hours on the tractor so far. The dealer has had to take it back to the shop once already and been out 2 other times for repairs. coming for a 3rd this week.
tractor issues so far.
Range selector cable the outer housing was not put together properly and wouldn't let you pull it out of park off the truck when it first arrived.
Missing O-ring/O-ring not seated properly crushed when tightened at factory. Oil was pouring out from power steering.
Air conditioning line kinked and tie raped wrong.
Tractor wont start thinking its the starting solenoid that's bad.
oil line for power steering going to steering cylinder, is chaffing on the stop block where the front axle is.
Has any one else had any bad issues with buying a new tractor like this. I Don't know if I would ever buy one of these tractors again, with all the issues I have had.
   / New Holland powerstar t4.75 #2
Welcome to TBN. Sorry to hear you have had so many problems. All in all, once you get all of the issues resolved, it will be a great tractor.
Could just be a Friday tractor, plus dealer didn't spend a lot of time predelivering the tractor,
I have a customer with 4 TN95FA's, the vineyard version, 3 which have 7,000 hours with several different drivers and very few problems. As a matter of fact, almost all the problems have been due to grape canes or citrus branches getting into lines and harnesses.
He just took delivery of 2 T4.95F's and right off, the PTO assist servo cylinders were leaking. Not great quality control in Italy on final assembly, but definitely a great product.
   / New Holland powerstar t4.75 #3
I believe the T4.75 is mfg. in Ankara, Turkey. Correct me if I am wrong.
   / New Holland powerstar t4.75 #4
I just had a friend purchase the same tractor;I hope he has better luck.
   / New Holland powerstar t4.75 #5
I have a 2015 powerstar with 70 hours on it since 3/26 and it has been absolutely flawless. I couldn't be happier with the tractor
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
Wright Sentar (A50120)
