New Holland model 1920 dashboard electrical problem
   / New Holland model 1920 dashboard electrical problem #1
Cordfed
Middle Georgia
Troy Built Pony, NH 1920, JD L130
Hello friends I'm having a bear of a time trying to get our family tractor back in the game and I would be very grateful if y'all could help us out. The gauges on the dash are not coming on, including the fuel and temperature gauge needles not moving either. The tractor starts and runs fine, headlamps come on via the switch including the backlight on the dash but not the gauges. Ive checked the three fuses under the good and have been try's to find any breaks in wires. I downloaded the operators manual when we bought the tractor but didn't see any help in there. This problem started after we had an almost electrical fire a couple weeks ago at our farm. My brother called me on the radio saying the tractor was smoking while he was riding through the woods an when I pulled up on the 4 wheeler a minute later we found a glowing hot wire running from the positive battery post all the way back to the cigarette lighter mounted on the tool box (wiring and such was there when we bought the tractor). We yanked the wires in a panic to break the live circuit and found the headlight wiring all melted and torn up, along with a couple of the wires near the starter and starting solenoid had been touching the hot wire and had insulation burnt through too. We cut out and real resolved the headlight wiring and it works fine again, and only used electrical tape on a couple wires near the starter that had copper showing. Can any of y'all help me find out if I am getting power to the dash? Thanks a ton in advance..
   / New Holland model 1920 dashboard electrical problem #2
If your operators manual did not have a wiring diagram, here is one you can use. Hopefully, your wiring has not been modified much from this diagram.
  • 1920 wiring diagram.pdf
Thank you so much! That image looks familiar, it may be in out .pdf of the manual but I didn't see it the other day. Do you by chance know what the item/ component is on the far left of the diagram, left of item 20 that looks to b getting power off the alternator?
   / New Holland model 1920 dashboard electrical problem #4
Don't know for sure but looking at the rest of the diagram there are 4 or 5 additional items with the same symbol that feed lights so my guess is that it is a light socket or some type of plug-in fixture.
I found the break and repaired it! Thanks again Kirk!! It was in the wiring right behind the console after the harness connector.
   / New Holland model 1920 dashboard electrical problem #6
Glad to hear you are running again. Those wiring problems can be very frustrating.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2000 Volvo VNL Truck, VIN # 4V4N21JF4YN250174 (A51572)
2000 Volvo VNL...
New Long Forks (A53002)
New Long Forks...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
