Dstrohl
I have a problem with diesel engine not starting. I get an Error 2 message on the EIC panel. All the lights light up, the pre-heat is functoning. I hear the ticking which I assume is the fuel pump. All fuses on the firewall are good. Can someone tell me where the fuel shut off solenoid relay is located. The engine turns over. The battery is new. The engine does not start in either the service or run switch position. The seatbelt light goes out when you sit in the seat and buckle up the seatbelt. Sure could use some advice.
