New Holland Lx665 turbo quit
   / New Holland Lx665 turbo quit #1
A J
Brainerd Mn
New Holland Lx655 turbo
While I was driving it........ acted like it was starving for fuel, engine kept slowing down and eventually quit. It has 1/2 tank of fuel... the filters are not plugged... the fuel pump is pumping.. fuel is getting to the injector pump..... and I can hear the fuel solenoid functioning when I disconnect-reconnect the power to it with the key on. It sounds like it wants to start and sometimes will barely run and quit. ???? Any ideas?????
   / New Holland Lx665 turbo quit #2
Fuel contamination could show same results. Do you know it's good? I'd siphon out and replace, with a conditioner added. That's a start.
Jim
Fuel looks clean. I cracked a high pressure injector line to see if I had fuel going there........... some but not shooting out hard, just little squirt. How hard should it be shooting????
2018 KENWORTH T800 (A53843)
2018 KENWORTH T800...
1999 MadVac 101-D Riding Compact Debris Vacuum (A51691)
1999 MadVac 101-D...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2018 Ford F-350 4x4 Crew Cab Service Truck (A51692)
2018 Ford F-350...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
