I have a 2017 New Holland T4 110. The Def system is still under warranty. It has been back to the dealer 4 times with the same code, but they only 吐ix it for a short time. Forced regen is always the first diagnosis then a return trip. Customer service just wants to keep being a liaison between me and the dealer without offering to repair anything without an error code for that part. The dealers say there are many recalls but New Holland will not replace parts like car recalls. Has anyone had this issue or had help from New Holland more than me?
We have a 2017 NH T4.90 with same problems numerous 19336 and 19071 codes over 14 since new. Been having them since we purchased it new in July of 2018 along with many other problems with the tractor, from the loader brackets failing numerous times to DEF tank leaks to loader valve issues, remote valve issues front wheels breaking it goes on....
The New Holland tractors are not what the use to be. I would of been better off keeping my old ones and rehabbing them, even if it meant a complete rebuild. We bought new replacement tractors so as not to have problems We've had a lot less issues with our old New Hollands and Fords then the issues, problems and break downs with these new ones!!
It was getting to costly to continually send it back to the dealer for warranty work (3 hours away)or have them come here as the warranty only covers working on it not transport to or from the dealer or travel time and mileage for a dealer tech to come here. I found and purchased a laptop with the interface and software on the internet and can now connect to the tractor to reset codes diagnose problems etc. I was instructed by the dealer never to idle below 1100 rpm (why isn't it set this way from the factory) and most times the codes set are when I have been working the tractor hard at rated speed (Hard to the point it actually starts to bog down at times) for quite awhile (Over an hour working hard so plenty hot enough)!!!!
I have found that it appears that the DEF injector is leaking/dribbling when it shuts off causing crystallization on the tip of the injector which is causing a high pressure blockage which sets code 19336. If you remove the injector from the exhaust(a real PIA) clean the tip with clean water reinstall and run the system test with the software you can then reset the counter, which clears the code and you are all set until the next time it happens.
I believe the entire DEF system is under warranty for 5 years and our power train extended warranty is for 5 years/3000 hrs. But after that the parts are so costly dealer lists $800+/- for the injector $5000 + for the catalyst we'll be looking for a DEF Delete kit soon. Others on TBN have said they are going through an injector nozzle every 1000 hrs, our nozzle appears it has been bad since day 1.
Hopefully the Federal Government will pass a right to repair law that will help Farmers/tractor owners with access to software, interfaces and online dealer repair info (like NH's Assist program) to assist with farmers/tractor owners making repairs to their own equipment.
Good luck with yours.
