new holland hydraulic problem
   / new holland hydraulic problem #1
bdb121
I have a N H 3010 that the hydraulic pump gets real hot (smoking) after about 20 min the fel operates ok the 3pt wont pick up a round bale to top of travel unless rpms at 2000
please help[
   / new holland hydraulic problem #2
I just know hyd's and not the NH, but it sounds like the wear plates are allowing fluid to slip by and the smokin part is probably the internal bearings getting worn out.
is there a way to prove this?
   / new holland hydraulic problem #4
Sounds like a pressure test is in order.
Ben
   / new holland hydraulic problem #5
A pressure test and gallons per minute will tell everything or disassemble the pump and mic the tolerences. most hyd pumps have needle bearings and even though they run in oil they do wear out. More so if any dirt got into it or moisture. I am sure that you have a gear pump which has wear plates and that is just what they do, they wear. In some cases replaceing the plates is much cheaper than the whole pump.
   / new holland hydraulic problem #6
You don't have a remote spool kicked open do you? That would work the pump ( and relief) over pretty well.
Soundguy
all spools are centerd. had fel joystick rebuilt not to long ago pump was a little weak prior to that
installed new pump today operated fine until i put fel in bind then no more pressure I think the shear pin broke I will find out next weekend
   / new holland hydraulic problem #9
Sounds like an obstruction in the fluid flow. Any "stop" or "servicing" valves closed, or internal pickup screen that needs to be cleaned or replaced?
replaced wooddrift key & adjusted bypass valve working fine now.
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
FRONTIER  ROUND HAY BALE SPREADER (A52472)
FRONTIER ROUND...
