New Holland Haybine cutting head springs
   / New Holland Haybine cutting head springs #1
ed prescott
New Holland
Ok, So I took the springs off the cutting head in order to rebuild the main support bar. I looked at the manual and it doesn't show how to re-attach the springs. They're about 6" from the threaded bolts and I can't figure out how to streatch them back. Any ideas on this? Ed
   / New Holland Haybine cutting head springs #2
What model haybine? For example, on a 479, when you disconnect the control arms (mine broke on 1 side), you can back out the spring tensioner until its loose. Then set the lower pin in and start tightening. To get the control arms back in place, I used a bottle jack to move the header back into position (which tensions the springs even more).
It's similar in build to the Hew Holland 1469. There are two large cutting head float springs on either side. When I was taking them off, the cutting head was in the lowered position and the springs had tension on them all the way to the end of theadjusting bolt, and then some.
   / New Holland Haybine cutting head springs #5
pick up the header with the hydraulics. Place a block under the header near the tongue, lower head back down. There should be enough "slack" to get the inside spring hooked up. Repeat for other spring, but place block on the outside edge of the header. (Opposite end from the first time you blocked it.)
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2239 (A51244)
2239 (A51244)
2009 Ford F-550 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2009 Ford F-550...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
