new holland disc mower
   / new holland disc mower #1
a1e
morristown,tenn
ford
I need the specs on a 617 new Holland disc mower
   / new holland disc mower #2
Welcome to TractorByNet!
I moved your thread to the Attachments forum. :)
   / new holland disc mower #3
I took this information from a spec sheet I downloaded a few years ago. Please pardon the spacing, not much I can do about it.
MODEL 617
CUTTER BAR
Cutting width, ft. in. (mm) 9' 2" (2800)
Cutting height, in. (mm) 95-3.25 (24-82.5)
Cutter bar tilt angle, degrees 0 to -10
Cutter bar operating range, degrees +18 to -28
Breakaway angle, degrees 19
Type cutterbar Modular
Number of discs 7
Knives per disc 2
Disc cutting diameter, in. (mm) 19.7 (500)
Disc drive Bevel gears in sealed modules
Disc speed, RPM 3000
DRIVELINE
Minimum PTO horsepower required, hp (kW)* 60 (44.7)
Input speed, PM 540
Driveline protection Belt drive to cutter bar
Overrunning clutch On PTO shaft
Belt tension Spring-loaded tensioner with adjustment gauge
HYDRAULICS AND HITCH
Hydraulic circuits required One remote
Minimum relief pressure required, psi (bar) 1500 (104)
Hitch Category II
DIMENSIONS AND WEIGHT
Overall width, in. (mm) 181.75 (4616)
Overall length, in. (mm) 50.5 (1283)
Height - transport position, in. (mm) 141 (3581)**
Weight, lb. (kg) 1535 (698)
* Recommended for use with tractors having a fully enclosed cab.
** Transport height is based on 18-inch (457 mm) hitch-pin height above ground.
2016 FORD F-350 (A45046)
2016 FORD F-350...
2000 SHOP BUILT SPOOL TRAILER (A45333)
2000 SHOP BUILT...
1998 Freightliner FLD120 Sleeper Cab  Detroit Diesel Series 60 Engine, 10-Speed Rockwell (A44789)
1998 Freightliner...
2011 HINO BOX TRUCK (A45046)
2011 HINO BOX...
2008 Ford Explorer XLT SUV (A44572)
2008 Ford Explorer...
2015 John Deere 4052R Tractor (A44571)
2015 John Deere...
