New Holland Boomer 37 PTO Switch Keeps Blowing Fuses
   / New Holland Boomer 37 PTO Switch Keeps Blowing Fuses #1
Skybird12209
May 13
Such a beautiful day here in Virginia, so I decided to cut my 9 acre field with my 2015 New Holland Boomer 37 tractor. After about 3 hours, I was almost done when I noticed that the blades were not cutting. Thinking that maybe there was a wire or brush under the deck, I checked and the blades were fine.
I turned the PTO switch on and off a few times and did not hear that typical clunk, meaning the PTO was not being engaged. I pulled the cover to some fuses under the steering wheel and I did find a 15amp fuse blown. I replaced it and poof, it blew again.
The icon on the dashboard does light up when the switch is turned on or off.
Any ideas? Help most appreciated, I still have about an acre to go.
   / New Holland Boomer 37 PTO Switch Keeps Blowing Fuses #2
If your PTO solenoid hasn't shorted out you may have a pinched or exposed wire somewhere.
Thanks Roadworthy. I found the solenoid, and I guess I can just try and replace it, but is there a way to check it? I pulled it out and see that it has a number of flat blades. I wonder if I can check it to see what I find. Finding a shorted or pinched wire would be a nightmare.
I located the actual PTO switch too, but it is a sealed switch with no way to test the leads like other PTO switches offer.
Thanks for your help.
George in Virginia
2013 INTERNATIONAL REEFER TRUCK (A53426)
2013 INTERNATIONAL...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2018 John Deere TX Gator (A50123)
2018 John Deere TX...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
