New Holland Boomer 3040 80 amp fuse issue
   / New Holland Boomer 3040 80 amp fuse issue #1
KKDDSS
detroit lakes
New Holland Bommer 3040
New Holland 3040 Master Fuse Issue
I am having issues with blowing the 80 amp master fuse located under the hood on a New Holland Boomer 2040 cabbed tractor. The tractor will be working normally and I will shut it off for something and go back to start it and I will lose all power. Nothing will be there....... The first time it happened I used the tractor for about 6 hours mowing and then I was disconnecting the 3 point mower and I got off the seat before placing neutral and killed the tractor. I placed tractor in neutral and tried starting the tractor from outside the cab. I could hear something pop when I turned the key, no power. After some further inspection I found the negative battery cable had worn through. I have replaced the cable but this problem has occurred again. All three times the exact same issue has occurred. Looking for some pointers.
   / New Holland Boomer 3040 80 amp fuse issue #3
I would trace your positive wire from the battery and I suspect that you will find a worn spot in that one as well.
Aaron Z
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56435)
2012 MACK Tender...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
