New Holland Bale Wagon
   / New Holland Bale Wagon #1
gargoyleridge
Ash Grove, MO
Kubota M6040
I'm looking at a New Holland bale wagon and I'm hoping for some input:
My concern is my driveway. It's blacktop but fairly steep. I will have to haul a loaded balewagon up my drive to the hay barn. I think that I would at the very least, need to buy a smaller balewagon rather than a 100+ bale model. My tractor is a Kubota M6040. It's 4wd with bucket and loader, but I'm concerned that it won't be able to pull the loaded weight of the bale wagon. Has anyone pulled a bale wagon up any sort of an incline? When they are loaded, how is the balance front to back?
The tractor meets the HP requirement of the bale wagon, but I wonder if the front end is heavy enough. If it's not enough to drag 10k pounds up the drive, would it be possible unhitch a loaded balewagon and connect it to my 1 ton dually, for the trips to the barn?
It would be a pain in the neck, but I'm wondering. I have been watching the balewagon videos online and these look like a great answer to my labor problem.
We just had our first haying and I realized right off that waiting for workers to show and worrying that they won't show is not a good idea. I don't really like the accumulators that I have seen online.
We will be baling 2000-3000 bales at a time and I need a good solid solution for picking them up and stacking in our barn.
Your input is most appreciated
   / New Holland Bale Wagon #2
I have a 1033 that I've only used a couple times (backup for my SP). I can tell you they are very hitch-heavy, to the point where the manual recommends reinforcing the tractor drawbar. I'm pretty sure they also warn in the manual not to unhook a full wagon from the tractor.
I think with the loader on the front you won't have any issues with front end weight, but I'd look at your drawbar & supports if you plan to use it a lot.
Remember also with the older models you cannot unload a partial load, so approaching the driveway with a smaller load isn't going to work.
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
(2) Ford Suitcase Weights (A50515)
(2) Ford Suitcase...
Wolverine Fork Extensions (A50515)
Wolverine Fork...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
