Quick Hitches New Holland 840TL with skid-steer quick-attach
   / New Holland 840TL with skid-steer quick-attach #1
Ann Valentine
Foster, RI
New Holland 840TL
The skid steer quick attach on the 840TL is not holding under pressure. This is happening with all implements, not just the New Holland. The pins appeared to be down and locked and while working just let go. Has anyone been having this problem?
   / New Holland 840TL with skid-steer quick-attach #2
A few things to check to determine what may be going on;
1. Spring tension - when you lock the levers down, is there plenty of tension from the springs or do the "flop" over
2. Pin wear - are the ends of the pins worn allowing the attachment to slip off
3. Pin engagement - When the implement is locked on, what portion of the angled section of the pin is contacting the edge of the "hole" in the implement? Mine are about the middle of the angles section.
If pins are sitting too shallow into the "holes", may need to open up the hole a little to get the proper engagement.
If pins are bottoming out and not holding implement tightly, you may need to weld a plate beside the implement "hole" to tighten it up.
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
8ft Perforated Metal (A51573)
8ft Perforated...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
