3-Point Hitch New Holland 6610S Hydraulics
   / New Holland 6610S Hydraulics #1
kbright
Ford 3000
All fluids and filters changed. 3-point lift will not pick up heavy equipment - need pump rebuild?
Inner rear remote raises but will not move forward to retract or float. - another rebuild?
   / New Holland 6610S Hydraulics #2
If all you did was change the fluids and the hydraulic filter, there's no reason why the lift should work any different than it did before you made the change. If it picked up heavy equipment before it should still do it now Your pump is a gear pump and so it should prime itself. Cycle the 3 point several times without weight on the hitch. You may have air in the lift cylinder that's hasn't been displaced by fluid.
2004 John Deere 6215 (A50120)
2004 John Deere...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
Cat 66" Skidloader Bucket (A50774)
Cat 66" Skidloader...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
